Deaver and Geiser?
sherwood
Santa Barbara, CA
I've spent hours reading on here about doing a Deaver and Geiser combo on these trucks. For the people that have done it, is it worth it? Meaning it's a $70K truck and seems strange to put another $2000 (not including installation) into a well engineered truck. My truck is my daily driver/weekend warrior so I don't need a race truck. Also, anyone self install? How hard was it?
zombiekiller
OG BooBooRunner
New Orleans
I'll tell ya what, search for "deavers worth it"
And let us know what comes back. :specialed:
ogdobber
100% worth it. best money i've spent. installation is pretty easy but you need a couple special tools. spring compressor you can rent from autozone and a good impact (milwaukee m18 fuel) to get the front lower shock bolt. other than that a good jack and stands
Truckzor
Count the number of leafs in your spring pack then count the number of leafs in a Deaver spring pack. Then ask yourself if well engineered means best performing or cheapest.
It's a Ford, at the end of the day.
murph145
Simi Valley, CA
I have this combo and truck sits higher and perfectly level with +3s
Truck rides better than stock and off roads awesome.
Do you need this combo? No but if you want to do it why not? If not save your $$$ spend it else where or just leave your stock Ford as is.
sherwood
sherwood
Santa Barbara, CA
I thought the +2 was level? Do you carry anything in the bed?
TXRaptor
The Deaver +2s are the same height as the factory leafs because you remove the 2" factory block. The Geisers springs raise the front past the height of the factory rear leafs, so you need the Deaver +3s to level it out again.
Higgs Boson
Texas Hill Country
I have the Geiser fronts and Deaver +3 rears and the rear sits about .2 inches higher in the rear than the front but I have only driven it 50 miles or so on the street, there may be more settling to be done.
murph145
Simi Valley, CA
^ yea mine sits exactly level with the Geisers and +3s
I love the feel and the look. When you see my Raptor next to a stock Raptor mine looks so much bigger and the aftermarket wheel fitment makes it look better with the stance.
