Always the smallest things V2
Muchmore
Kansas City
I'm going to piggyback off of @Hdaniel85 in his Always the smallest things thread....
I have been having this noise in the tailgate for some time. Clearly something had come loose in there and was rolling around every time I raised or lowered it. I took the access panel off but it really doesn't show that much at all. I shined a flashlight in every orifice I could find but still couldn't see a thing.
So, I ended up taking it to the dealer, nice guys. They called and let me know it was done, he said I needed to come to see it but everything was fine now. Luckily there was no charge but they did get a good laugh at my expense and I obliged. :D
GCATX
King Dingaling
Central Texas
Nice. Do you have the tailgate step? Wonder if one of your shooting buddies pulled the step out and inserted the shell.
I am going to file this one away for later use on my ******* buddies.
Muchmore
Muchmore
Kansas City
Look on the bottom of the tailgate there is big draining holes in between it and the bed. I was setting on one side of the tailgate ejecting shells into the bed. Lesson learned!
But yeah look at the bottom of your tailgate with it open, in between the gate and bed.
Russ103
MD
I found a 9mm live round inside the floor vent (under the drivers seat) of my wife’s Benz shortly after purchase (used). I began to hear something rolling/rattling around and eventually found it.
When I set up my belt fed in the bed, I latched down the tripod, loaded up, racked and cut loose. It was a great time... Until I had to work my way out of the truck bed. There is no easy way to deal with a bed full of empty cartridge cases.
Or so I thought. As it turns out I was lobbing steel cased 8mm so I used a big @$$ magnet to help, because sweeping them out just jammed them into the gap between the bed and tailgate.
I can sympathize.
I have it on my “to do” list to use the tailgate step pole stripper pole as a sort of monopod. I figure i just need to preload it and keep the movement down to a minimum.
I’m thinking I could use the equivalent of a fist clamp around a free float tube or something along those lines.
