ADD Race Series R front bumper install help
PCDan
Park City
Has anyone installed the new front Addictive Desert Designs race series R front bumper. There are No directions on the ADD website duh! Its pretty straight forward other than connecting to the lower control arm.
***SEE MY POST ON PG 4 FOR ANSWERS AND INSTRUCTIONS.
thanks
Dan
Rookie
Fort Wayne, IN
It straightforward. How it looks is how it goes. I had to call add because they included alignment cams which I know nothing about. Ended up not installing them. When I take it off to line x I'll reinstall with them on.
Call and verify but if I recall, the long bolts were for the front lca mount and the shorter for the back. I used the factory bolt for now.
I will say I wish there had been some documentation for installation. Didn't find out I'd need an alignment until after I asked ADD about all the bolts.
PCDan
PCDan
Park City
Yeah, I don't know what the cam washers are for really, and why is there even a replacement LCA rear bolt?
Anyone know if the LCA bolt can be pulled and replaced with the longer one with the truck on the ground? … without the LCA moving?
Rookie
Fort Wayne, IN
Not sure about the rear bolt. My guess was a better quality. I was just going to call them when I finally get line x on it. Which might be never. lol.
I was also worried about pulling the bolt and getting the new one in. At a minimum you'd probably have to take the weight off the lca. Removing the wheel might help too.
PCDan
PCDan
Park City
I will probably just take it into the shop, because you can't really mark the spot to drill the extra mounting hole in the frame horn properly unless you take off the LCA nut and back out the bolt so that the lower bumper mount fits flush against the frame.
The cam washers seem useless since, and I don't see any reason for the rear LCA bolt replacements ? Cant believe they don't have directions or explanations.
Rookie
Fort Wayne, IN
I will probably just take it into the shop, because you can't really mark the spot to drill on the frame horn properly unless you take off the LCA nut and back out the bolt so that the lower bumper mount fits flush against the frame.
The cam washers seem useless, and I don't see any reason for the rear bolt replacements ? Cant believe they don't have directions or explanations.
I was supposed to drill a hole for something? Lol. Shit.
Maybe ADD can chime in. @Addictive Desert Designs
Orionkhan
SoCal
I was in the same boat. I think I used the LCA factory bolt. They really need to create in installation guide. It's not that difficult to do, but not having any explanation about the hardware sent just creates confusion. I do love the bumper. I just wish the factory tow hooks stuck out a little further. I don't think a shackle can fit through the opening on them now.
PCDan
PCDan
Park City
LOL … well you drill a 3rd hole in each frame horn for the other bumpers but who the hell knows with this one HA!
---------- Post added at 05:51 PM ---------- Previous post was at 05:46 PM ----------
Hmmm yeah not knowing why they sent cam washers and the rear LCA bolts is confusing.
BTW Looks super sweet! i went with the same setup but with a 20" lower light bar and no winch.
Orionkhan
SoCal
I almost opted for no winch. But I already had a 40" in the grill. And ADD had the winch on in stock when I called to order. Had it delivered within a week. Here's a shot with the lights on prior to the hood graphic being installed.
