jnrush16
Have any of you folks swapped out the plain dual zone temp section for the LCD temp reading? My OCD really wants to add that back in. “Plug and play” can still be a tedious process.
Someone here posted they did it, showed pics, part number. Another member then followed suit. I want it also. Found one on eBay for about $350 but it was scratched. The OEM part through ford is $850. And if you do look for it used, be careful as there are letters at the end of the part number that can differ. But they need to match.Have any of you folks swapped out the plain dual zone temp section for the LCD temp reading? My OCD really wants to add that back in. “Plug and play” can still be a tedious process.
How did the door panels come off? Do you need to pull the entire panel off?I have replaced all four door lights and I'm working up the courage to put the cup holder light back in, but pulling the interior out of a brand new truck is nerve wracking......
Yes, entire panel needs to come off. It has a few bolts. There are YouTube videos that show in detail the removal of 2021-2022 for panel removal.... super easy.How did the door panels come off? Do you need to pull the entire panel off?
$1000 would be worth it. What’s not worth it is the time and hassle of pulling apart a new truck and having to mod some things to fit those parts. If someone told me for $1000 the offered a service there I drop the truck off for a day and it comes back with all this perfectly done I’d do it.Was it worth it?
Just ordered $386 worth of interior lights that Ford omitted... Wondering if its all worth it...
Was there ever an update on this? Also, is there any instructions how to do this swap (including part numbers)? I would really like to add those cup holder lights into my '22.I’m trying to order the ‘21 cup holders ($29) but Ford parts can’t seem to get the right part. You’d definitely have to trim the ‘22 piece and the cup tensioners would be slightly ’off’.
I love the marker lights. I found out that the Raptor needs these lights due to the truck's width (not height). When Ford widened the Raptor to allow for the Fox Shocks and aggressive stance, it pushed it over that 80″ width rule, meaning they had to have clearance lights. Moreover, I love interior car lighting. It has several colors that come in handy when you want to match them with your mood. Also, it was surprising to me that not all models have light in the cupholders.
So you have to replace the entire unit to get the readouts?5. LCD Readout Temperature Adjustment Dials (I have added this back, this is plug and play) - 2021 Platinum Part # ML3T-18C612-DE
