- Joined
- Dec 16, 2016
- Posts
- 16,429
- Reaction score
- 24,283
yeah, a little Krytox goes a long way and will last a long time. Post track replacement, I requested my stealership lube the moon roof seals and they were all too happy to. Local stealership where I’m at now are like “sure, but it will be an extra cost, that stuff is expensive”. Since I have my own, I’ll save that cost and do it myself. (gentle reminder to self, it’s about time).
This almost sounds like the track might be bent. Has it had a failure previously, or did you hear the dreaded “pop” previously and it’s not given you trouble since?
Great info thanks! I do have a question though? Mine works well with the exception of opening due to the tight fit. I hit the button and it tries to open but then I have to get out and give a push down then it opens! The felt is clean ,I greased the tracks with special ford grease but gets stuck. It will pop up no issue but down to open no dice with out pushing down. What am I doing wrong here? What do you put on the felt (edge of sunroof)
