CVFAB intercooler fan
Ali 556
Home
The CV FAB IC is 0.5" thinner than my mishemoto IC, and my fan fit perfectly fine.
I think you didn't secure them in upper holes correctly.
The hard lines are for the engine oil cooler.
J
JustRaptor1
Florida
I had someone install for me, I guess I’ll have to order another one and try again since one of the 3 pieces on back of it is broken causing all the noise.
Unless anyone has an idea how I can rig it
Ali 556
Home
Hold up, remove the plate (4x 13mm and 2x15mm bolts.
Jack the front on ramps (you don't need a lift) and see what's going on, if the fan damaged the IC go back to him and kick his arse, is the is misalignment go and kick his arse.
If you are near me I'd do it for free for ya, where are located?
J
JustRaptor1
Florida
South Florida where are you located ?
DeepImpact
Miami
What part of south Florida, I installed my CVF couple of weeks ago and only trimmed my shroud like 1/2”. I can check it for you if you want?
Staff online
93,171
56,440
jumpcutter
