CVFAB intercooler fan
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by JustRaptor1, Jul 4, 2020.
  1. Ali 556
    Ali 556 Full Access Member
    68
    15
    Feb 22, 2020
    Home
    The CV FAB IC is 0.5" thinner than my mishemoto IC, and my fan fit perfectly fine.
    I think you didn't secure them in upper holes correctly.
    The hard lines are for the engine oil cooler.
  2. JustRaptor1
    JustRaptor1 Full Access Member
    112
    44
    Oct 3, 2019
    Florida
    I had someone install for me, I guess I’ll have to order another one and try again since one of the 3 pieces on back of it is broken causing all the noise.
    Unless anyone has an idea how I can rig it
  3. Ali 556
    68
    15
    Feb 22, 2020
    Home
    Hold up, remove the plate (4x 13mm and 2x15mm bolts.
    Jack the front on ramps (you don't need a lift) and see what's going on, if the fan damaged the IC go back to him and kick his arse, is the is misalignment go and kick his arse.
    If you are near me I'd do it for free for ya, where are located?
  4. JustRaptor1
    112
    44
    Oct 3, 2019
    Florida
    South Florida where are you located ?
  5. Ali 556
    68
    15
    Feb 22, 2020
    Home
    Far away, half way around ze world.
  6. DeepImpact
    DeepImpact Member
    Jun 10, 2020
    North Miami
    What part of south Florida, I installed my CVF couple of weeks ago and only trimmed my shroud like 1/2”. I can check it for you if you want?
  7. JustRaptor1
    112
    44
    Oct 3, 2019
    Florida
    im in Boca where are you located ?
  8. DeepImpact
    DeepImpact Member
    Jun 10, 2020
    North Miami
    I’m in Miami, if you are Willing to take a drive down, I can check it out For you
    Flash1034 likes this.
Share This Page
