FordPerf Addict
- Joined
- Aug 24, 2016
- Posts
- 1,333
- Reaction score
- 530
Looks great! Just picked these wheels up in black for my white raptor
I just want the upgraded design, if they will do it. I’ll probably find out where it covered the shock, that it scuffed the shit out of it. If I upgrade to aftermarket shocks I will definitely want them more exposed.You want the latest version basically to expose the shocks? Personally I wouldn’t have gone this route if they covered mine. I think all the whole truck is like eye candy to me lol
just curious b/c I plan on adding console gun safe as well- why did you go w/ this brand in particular? I had “lockerdown” in previous truck & planned on looking into that for the Raptor- not sure what install is like yet on the Ford but on my GM def didn’t need to take much if anything apart.
I just did the same. Big difference!! Only thing I didnt like was that I had to cut them some to make them fit. But definitely worth the $ and effort.
Had to cut the outside lip about 1/2" all the way around. It absolutely just would not fit/tuck in under the fender well without cutting it. Once I did it went in seamlessly and fits great on both wheel wells.What areas did you cut? Might be obvious once I ha e them but would love some tips before I get started.
I used a handheld jigsaw and just went from one end to the other about a 1/2" in all away around the outer lip. It still fits very snugly and still took some effort to get all of the lip tucked into the inner wheel well, but looks and fits great now.Awesome info thanks. What tool did you use to trim?
Started with just a 1/4" but with two of us, we still just couldnt all of the liner lip to fit under, so we took another 1/4" off and then could finally get it tucked in.I only shaved about 1/4-1/2” off of one end and it was the first liner I installed. I really only shaved it as it wasn’t trimmed as smoothly as the other ends from the factory. It may have made bending it in just a little faster. But try not to cut these up or you may find in the end you have loose fitment. Takes some patience, but you will like the look.
https://www.lowes.com/pd/BLACK-DECK...MIzZz_7pDn5wIVmZOzCh0bQQUuEAQYAiABEgJWqfD_BwEThanks again for the info, but moreso thank you for the excuse to buy a handheld jigsaw
