CHMP
Santa Cruz
Yes from what I learned they came out with a new version with more shock clearance for the Raptor. I basically just ordered that newer part number. I did not want to hide the shocks.
Ordered a set myself last night. Seeing the white bed in the wheel well drove me nuts for too long. How was the install?
Bat
Usa
Will likely have to shave it down a bit to get it to fit. It's really tight, and takes a lot of prying on the fenders but worth it when you're done. Not seen anyone do it yet without shaving on them a bit.
K223
Florida
These should really make a big difference on a white truck. You have to man handle them to some degree, but if bend the ends and work them in, it’s not bad. Takes some patience. But otherwise its not complicated. Once in there solid.
K223
Florida
I only shaved about 1/4-1/2” off of one end and it was the first liner I installed. I really only shaved it as it wasn’t trimmed as smoothly as the other ends from the factory. It may have made bending it in just a little faster. But try not to cut these up or you may find in the end you have loose fitment. Takes some patience, but you will like the look.
