Gary E
Medford, Oregon
It’s awesome until it’s not. Burned the throttle sensor on the pedal and caused the truck to lunge randomly when brakes were on. When it works it’s fun and I agree feels better but people should be aware that there are problems also.
"It's awesome until it's not..."
That can probably be said about any after-market part, like a tune, brakes, power steering pump, tie rods, etc.
SZDZMTR
Sewell, NJ
Installed some side lightning in the ADD Venom R bumper using a pair of Rigid 6” SR-Series Pro’s. Not a big fan of Rigid but the bumper is designed for these and has slots that fit it perfectly.
Looks great Rick. And yes perfect fit for these lights. Do they have optimal amber covers?
Sent from my SM-G960U using Tapatalk
Deleted member 12951
Perfect fit because the bumper was designed around only those lights. Rigid does not currently have amber covers for these (they did for the older style) but I am told they will in about a month. I can always put some amber film on them instead, might look better anyways. But I don’t run my lights unless I off-road as all my lights have a single purpose to turn night into day when on the trails at night. I have a single 40” amber behind the grill that I use when things get dusty and flip off all the white lights
oxfordraptor
The Pedal Commander did that? Figure out why? What setting did you use?
Yup not the only one it happened to here either. It’s one of those things you get and then realize ok this ain’t worth it. Most have zero problems but I was at a full stop brakes on and the truck started lunging. Ford still warrantied the sensor even with it on. They said if it failed again though it wouldn’t be replaced.
