2017 - 2018 Raptor Updates
zombiekiller
OG BooBooRunner
New Orleans
Accessport is up to date. Waiting to hear from Cobb. Sounds like it might be an issue with the tune my Tuner created because the codes stay off with a Stage 2 OTS tune.
Codes in question were P0630 and U0422
did your tuner compile your tune with the tire size set to something other than 34.4?
If so, that tune is gonna need to be re-compiled with the tire size set to stock.
push the tuner your stock file with the OEM map and have them set all or their parameters.
Install the new tune, THEN change the tire size manually. Don't compile the tire size change into the map that you flash.
GBRaptor34
Northern California
when you load the tune? or when it is flashed back to stock?
can you not clear it at all?
I cleared the code. Put the tire size back to factory and uninstalled the tune and code remains. I reloaded the tune with updates and left the tire size at stock and code goes away, so I tired uninstall it again to see if the code went away and it remains
BIGDJE
OC, CALI
Still no idea what is taking Cobb so long all they need to do is verify any map changes on ECU vs 17 and 18 whipple had their 19 tune ready back in January Cobb evey month pushed to next month at this rate the transmission tune be ready in 3 years
Sent from my SM-G975U using Tapatalk
Nick@Apollo-Optics
COBB TUNING 2019 SUPPORT IS LIVE!
2019 Raptors are now supported for both Stage 1 ECU Maps. You can can the Stage 1 ECU Map as a standalone with the AP3 only, you can run the Stage 1 Power Package with the tune and drop-in filter, and you can run the Stage 1+ Package for the CAI and Tune. We have them all in stock!
Link to our site with all COBB Products: https://www.apollo-optics.com/collections/vendors?q=COBB Tuning
Accessport v3 Tuner: https://www.apollo-optics.com/products/cobb-accessport-v3-f-150-raptor-2017-2019
Stage 1 Power Package: https://www.apollo-optics.com/products/cobb-power-package-stage-1-f-150-raptor-2017-2020
Stage 1+ Power Package: https://www.apollo-optics.com/products/cobb-power-package-stage-1-f-150-raptor-2017-2019
Please let us know if you have any other questions!
Stage 2 support is currently undergoing R&D and will be available later this summer.
93,180
56,460
khunter
