Where to get +12v remote turn on wire?
BIRDMAN
BIRDMAN
Birdministrator
Boston
When you remove the audio module there is a connector in the back that has about 15 wires going to it. there is a grey wire with violet tracer that is going to be hot with the key in start or run position. There is also a blue wire that is the delay accessory wire so you will have 12volts with the key on and running then it will stay powered up when the key is off with the radio and when the radio shuts off so will the amp.
where might i find the audio module?
IRONMAN
Well-Known Member
MICHIGAN
alright smartass, where is my truck?
Right where you left it.
dataustin
Ditto on dismantling. I was referring to the photo where he claims to tap into power controlled by the ignition. Maybe I read it too fast.
BIRDMAN
BIRDMAN
Birdministrator
Boston
no, you're right. i missed it. does anyone know what fuse this is and what type of tap that is?
Stepside
Found this - should help
ATC Add a Fuse Circuit
The ATC fuse block extension plugs into an occupied or vacant fuse slot and turns it into two circuits. Perfect for adding a circuit to an existing fuse block. Holds 2 ATC fuses. Includes an output wire for the added circuit with a butt splice on the end for easy circuit integration.
ATM Add a Fuse Circuit
The ATM fuse block extension plugs into an occupied or vacant fuse slot and turns it into two circuits. Perfect for adding a circuit to an existing fuse block. Holds 2 ATM fuses. Includes an output wire for the added circuit with a butt splice on the end for easy circuit integration.
Click on this below:
Fuse Holders
BIRDMAN
BIRDMAN
Birdministrator
Boston
I bought this today. Should be easy to plug in to a fuse on my passenger side kick panel and run te wire under my door sill panel back to my amp.
Sent from my right thumb using Tapatalk.
93,171
56,440
jumpcutter
