Where to get +12v remote turn on wire?
Discussion in 'Ford Raptor Problems and Questions Forum' started by BIRDMAN, Dec 30, 2011.
  1. BIRDMAN
    BIRDMAN Birdministrator Staff Member
    12,906
    6,102
    May 16, 2010
    Boston
    where might i find the audio module?
  2. IRONMAN
    IRONMAN Super Moderator Staff Member
    9,024
    2,343
    Jun 21, 2010
    MICHIGAN
    In the truck! :hidesbehindsofa:
  3. BIRDMAN
    12,906
    6,102
    May 16, 2010
    Boston
    alright smartass, where is my truck?
  4. IRONMAN
    9,024
    2,343
    Jun 21, 2010
    MICHIGAN
    Right where you left it.
    [​IMG]
  5. dataustin
    dataustin FRF Addict
    2,294
    816
    May 3, 2011
  6. BIRDMAN
    12,906
    6,102
    May 16, 2010
    Boston
  7. dataustin
    2,294
    816
    May 3, 2011
    Ditto on dismantling. I was referring to the photo where he claims to tap into power controlled by the ignition. Maybe I read it too fast.
  8. BIRDMAN
    12,906
    6,102
    May 16, 2010
    Boston
    no, you're right. i missed it. does anyone know what fuse this is and what type of tap that is?
    [​IMG]
  9. Stepside
    Stepside Full Access Member
    588
    169
    Sep 17, 2011
    Found this - should help
    ATC Add a Fuse Circuit
    The ATC fuse block extension plugs into an occupied or vacant fuse slot and turns it into two circuits. Perfect for adding a circuit to an existing fuse block. Holds 2 ATC fuses. Includes an output wire for the added circuit with a butt splice on the end for easy circuit integration.
    ATM Add a Fuse Circuit
    The ATM fuse block extension plugs into an occupied or vacant fuse slot and turns it into two circuits. Perfect for adding a circuit to an existing fuse block. Holds 2 ATM fuses. Includes an output wire for the added circuit with a butt splice on the end for easy circuit integration.
    Click on this below:
    Fuse Holders
  10. BIRDMAN
    12,906
    6,102
    May 16, 2010
    Boston
    [​IMG]
    I bought this today. Should be easy to plug in to a fuse on my passenger side kick panel and run te wire under my door sill panel back to my amp.
    Sent from my right thumb using Tapatalk.
Share This Page
