Clockton
Just carry a few OEM filters, they are $13. I usually replace the filter every day during dusty runs and just dump the used filter. Easy
I do the same thing and keep a extra filter in the truck just Incase...Just carry a few OEM filters, they are $13. I usually replace the filter every day during dusty runs and just dump the used filter. Easy
I like the idea of just carrying an extra OEM filter...
On my last truck I switched to an oilable filter, and went straight down to watch the Baja 1000....first real WOT run thru a sand wash the truck went into limp home mode...after thinking the last thing I did was the filter, I pulled the MAF and cleaned it with brake cleaner...sure enough that was the issue.
Use a throttle body cleaner much saferdon't clean your MAF with brake cleaner
use MAF cleaner or electronics cleaner
brake cleaner can leave a residue as well as being tough on plastics.
Yeah...BUT when in Baja you use the tools you have...
but you are correct...
I did not know that thanks!It doesn't matter what you use, the 3.5 Raptor doesn't have a MAF sensor...
