Welcome to the Ford Professional Forum!
TeamFordRaptor
Las Vegas, NV
Hey Raptor Lovers! My name is Aaron McCleese, I'm in the employ of Team Ford-Lincoln-Mercury in Las Vegas, NV as a Master Certified Product Specialist in everything Ford, but especially in Raptors!
This forum is here for product/Raptor updates, accessory availability, special incentives on vehicles/Raptors and associated accessories, parts and service updates, along with problems & resolutions, and everything in between.
From info and the start of your hunt for the perfect Raptor, to finish and the selling or trading of your Raptor; I'm here to help. My contacts at Ford and the engineering department will make this the most detailed forum you will find. Feel free to contact me personally with problems, questions, or concerns you don't wish to express on the forum. Thanks!- Aaron
GMNOMORE
Spring Lake, Mi
Haven't been to my dealer yet but have you heard of any problems with what appears to be something loose in the front suspension? when driving over small asphalt bumps especially the right front rattles and I can feel the rattle in the gas pedal!! Not sure if that is a characteristic or what. Putting the brake didn't make a difference.
pirate air
will plunder your booty
There is a TSB (Technical Service Bulletin) that covers a clunking noise in the Raptors suspension. Basically it states that it's normal for the internal bypasses in the Fox shocks to make clunking noises over bumps. Thats probably whats going on with yours. I know my shocks clunk pretty noticeably when cold but quite down some when they warm up. But probably wont hurt to have your dealer take a peak at it just in case you have more going on.
Hockster
My 45ft Bluewater Party
Winchester, Va
When you say small bumps are you talking about speed bumps??? cause I have never had a vehicle that didnt make a rattle noise when going over them...
GMNOMORE
Spring Lake, Mi
Thax for the info,, will go to Mr Ford and have it checked out. The clunking noise happens on typical street asphalt patch work, I do think it improves with time on the road. I'll let you know what my dealer says,,, they have been very helpful in the past.
GMNOMORE
GMNOMORE
Spring Lake, Mi
Big surprise after being at Ford today,,,it was the shocks!!! BS. My Ford dealer found nothing but heard the clunking in the front. Gave me a Ford Motor Co. response,, "this is normal and do not attempt to correct! Fox Shocks, some customers may hear a boom, chirp, or clunk noise from the front and rear shocks most often heard over small sharp bumps from frost heaves, potholes or expansion joints. This is normal originating from the hydraulic motion of the fluid..blah, blah " I am all in with the action,,, $50 grand is to much for this noise,, there is a problem!
nodak
san diego
i have been hearing a bit of a squeak in the rear end. i think it is coming from the rear shocks. i hear it almost every time i stop at light and whenever you come to a complete stop. is this bad?
BIRDMAN
Birdministrator
Boston
probably the leaf springs. grease them and learn to live with it :D
tahoeacr
Lake Tahoe,Nv
Aaron,
Can you find out the straight up on this option. Sel opt 428 Hi Alt use. That is what I saw. Looks like high elevation mapping. Can you order this and block heater on a truck even though your a flatlander dealer? I live at 6,500' and rarely drive below 5k.
Thanks
