UPGRADES! Let’s play how much can I spend on my cooling system...
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by Booth9999, Aug 4, 2020.
  1. Booth9999
    Booth9999 Professional basket weaver level 7
    41
    1,564
    563
    Nov 19, 2017
    Idyllwild
    So FMIC on the truck and it got a little warmer than I liked in my recent torture test and I want to make her a little more bullet proof cooling wise. I just bought the full race radiator and transmission cooler. I figure while I’m in there I should do everything I can, anyone have any other ideas for me? I was thinking silicon hoses and new clamps but having a hard time with my google Fu. Any ideas appreciate!
  2. CoronaRaptor
    CoronaRaptor FRF Addict
    14,594
    3,914
    Dec 17, 2012
    CANADA
    Is this a gen1?
  3. Booth9999
    41
    1,564
    563
    Nov 19, 2017
    Idyllwild
    Gen 2
  4. The Car Stereo Company
    The Car Stereo Company aka nosbusa Supporting Vendor
    42
    26,078
    9,244
    Jul 8, 2012
    here, on frf
    sprinkler system. and carry 50gallons of water in the bed so when it gets hot you can turn the hose on and spray it down
    can you put a couple fans on it in front? might help cool it down. i would say a bigger trans pan but i think they hang down too low and might get beat up offroad
  5. Booth9999
    41
    1,564
    563
    Nov 19, 2017
    Idyllwild
    No can do, it’s got a FMIC and the fans are on the rear. Anyone seen/using a silicon hose kit?
  6. Ali 556
    Ali 556 Full Access Member
    74
    19
    Feb 22, 2020
    Home
    Easy, FMIC means you have removed the stock shutters ?! If yes, get an colder Tstat, make your tuner re-programe the curve to start earlier and get a water wetter.
    If needed a 29$pump can be found on Amazon and 9.99 will get you some 3/8 line with some "mist" nozzles.
    Plump them to your windshield wiper fluid for starts, if it does work with you get a separate tank.
    A retune with a richer AF ratio will net you a cooler engine.
    If a radiator is needed, I'd suggest either a ron Davis rad or Be cool rad, both of them are custom made to order, AND they are thicker walled and stronger than mishemoto, also you can ask them for thicker/taller rad as it's custom made.
    Booth9999 likes this.
  7. sixshooter_45
    sixshooter_45 Ruby Red Metallic Supercrew, 3.5 L Twin Turbos.
    874
    292
    Jun 17, 2012
    Arnold
    Not sure if it's a fact but on another post someone mentioned water wetter was garbage and suggested another product.
    Not trying to be negative but just wanted to pass it along in case you'd want to do some research on it or that post.
  8. Ryan James Nolan
    Ryan James Nolan Full Access Member
    314
    93
    Nov 16, 2019
    Yuma, AZ
    Are you saying Mishimoto makes the Full Race Motorsports rad and trans cooler?
  9. Ali 556
    74
    19
    Feb 22, 2020
    Home
    What?
    How did you understood that?
    For a rad, Ron Davis beats all rads.
  10. Ryan James Nolan
    314
    93
    Nov 16, 2019
    Yuma, AZ
    Because he said he bought the FR rad and trans cooler then you started saying, "and they are thicker walled and stronger than mishemoto" as in younare saying they are the ones who manufacture the FR ones.
Share This Page
