Tweeters in A-Pillar wiring
Torchy
Nevada
Hi All,
How did you run your tweeter wires from your a-pillars to the rear of your cab?
I was planning on running my power from the battery down the passenger side of the cab so was thinking that'd make me want to run the passenger tweeter wire under dash to driver side then run both together down driver side to rear of cab to amp board.
Am I thinking about this correctly. Are there any tips/tricks to getting the wire across the dash and to the drivers side?
Also any good vids on how to take the side dash trim panels off? Also how do I loosen up or remove rear c-pillar interior trim panel? It'd be the tall piece that the side seatbelts retract into that spans from floor to ceiling.
Thanks guys!
T
Torchy
Nevada
I used a very long beefy ziptie had to tie a few together but it worked great !!!
Can you expand on that? lol
Where? Like from a-pillar to bottom of dash? Or is that how you got the wires across the center console under the dash?
CNAIMO
Central Mass
I popped off the center speaker so i can maneuver the ziptie with the speaker wires taped to it. Across the top of the dash. Then pulled off the end pieces of the dash and the kick panels.
goblues38
STL
it is seriously a1 on the scale of 10 for jobs to do. Don't over think it....just run the wires. Drivers side approach is great.
