Are you positive it was a trans slip? There are several things that can mimic a slip. I had a coil start going bad on my old f150. It only misfired periodically when locked up in OD at low rpm. Not bad enough to trigger the CEL. Had the dealer do a stress test on the coils to find which coil was bad. I'd look for latent codes before jumping into the trans.
