jabroni619
- Joined
- Jun 13, 2017
- Posts
- 2,057
- Reaction score
- 1,419
I'm planning to get a fluid exchange done on the tranny next time I take it in for an oil change, what type of fluid does the 10 speed use? This is an early 2018 build.
If you believe fluid will last the life of the transmission, I’ve got some fully synthetic blinker fluid to sell you.
My 95 C1500 had the same fluid in for 150k miles, and was doing great. Stupidly let the dealer talk me into a full flush over drain & fill, and the truck never shifted as smoothly again. Still doing fine at 210k now, but given how oil has tripled in longevity in the last decade, I would be hard pressed to not think the same applies for transmission fluid.
That's because you went too long to begin with. If you go that long, you're on borrowed time and likely the only thing keeping from slippage is the excessively dirty fluid giving you just enough friction between the clutch packs to work. Regular changes and that isn't an issue and tranny will be far happier. Even the fordtechmeculoco (a ford tech if you're unfamiliar) channel says the fluid change intervals Ford advertises are complete BS and that they've started walking back the lifetime fluid claims on some parts/cars
