Tire Size Recommendations
Discussion in 'Ford Raptor Wheels & Tires Forum [GEN 1]' started by CO DUSTORM, Dec 28, 2017.
Texas Motorworx
  1. CO DUSTORM
    CO DUSTORM Member
    35
    20
    Dec 28, 2017
    Monument, CO
    Just picked up a 2012 SCREW with 17K miles. It has the stock wheels (machine faced w/black) and tires. Keeping the wheels, what is the largest tire size that can safely fit on these wheels?
    Thx in Advance
  2. CO DUSTORM
    CO DUSTORM Member
    35
    20
    Dec 28, 2017
    Monument, CO
    Let me add...leaving all stock, no cutting, street driver, if dirt will be very tame.
  3. Hockster
    Hockster My 45ft Bluewater Party Supporting Member
    62
    5,144
    1,860
    Aug 9, 2010
    Winchester, Va
    If I remember right the gen 1's you have to clean up some the wheel well in order to go bigger. Any 37 will run in jounce with out modding the wells.
  4. Rick@FreedomMotorsports
    [email protected] FRF Customer Support Specialist Supporting Vendor
    775
    543
    Oct 31, 2016
    Stock BFG's are actually 34.4". Something like a Toyo or 35x12.5x17 will be a true 35". I wouldn't go any bigger unless you change your mind and do some trimming but ultimately a set of 37's would be the best for it. The BFG 37's are actually like the stock, being at 36.5". They will work if you don't plan on going off-road or make full lock turns. recommendation would be to replace fenders and cut/pound out the pinch weld.
    Plenty of threads here on tires, plenty.
    Dre01SS likes this.
  5. tmd11111
    tmd11111 Full Access Member
    55
    261
    150
    Nov 6, 2017
    99% of the 35x12.5's out there measure around 34.5", a whopping .1" larger then stock. The Toyo's measure 34.8".
  6. CO DUSTORM
    CO DUSTORM Member
    35
    20
    Dec 28, 2017
    Monument, CO
    Been a year now, still researching and not any closer to making a decision on 35 or 37s. Keeping stock rims, stock perch, no pinch (no mods) and a street driver (only off road will be dirt roads hunting). As high as the truck sits with stock 35s (34.4”) it’s hard to believe I’d have problems with a 37 BFG AT or K02 (36.3”). Am I correct in thinking that’s only about 1” more rubber with turning/bouncing clearance? How is that a problem for the way I’m using it?
    Thx in advance
Share This Page
