t_j's build thread
t_j
Chicago, IL
Base truck:
2010 - 6.2L - Molten Orange
Lighting:
  • 40" Totron Bar behind the grill on rigid mounts
  • 4 18W Totron Pods on ridged mounts in the bumper on Rigid mount
  • 2 18W Totron Pods on rear rack with Sho-Me 11.1005STT Stop Tail Turn controller
  • Olympus Off Road long throw pods on sdhq mounts
  • Olympus Off Road rock lights for bed and under hood lighting (% hood left to do)
  • Roof Rack lighting
    - 2* 9" rear facing 54W bars
    - 50" 288W forward facing bar
  • DIY Retrofits
    - Base - Spyder projector headlights
    - Quad Morimoto H1 Mini 6.0 projectors
    - Quad Morimoto H1 XB 5500K Bulbs
    - Quad Morimoto XB35 35W Ballasts
    - Quad Morimoto XB Ignitors
    - Quad 90mm Green Halos - Wired with 2 relays and diodes so they come on with parking lights and turn off with the headlights.
    - Dual Morimoto Motocontrol H13 Harnesses
    - 10 1W 194 LEDs
    - 3157 LED Turn & DRL bulbs with load resistors
    - Sho-Me 11.1005STT Stop Tail Turn controller for 10 1 LEDs
Suspension:
  • Icon Bump Stop System
  • WSI HD leaf springs
  • Icon 3.0 rear bypass shocks
  • Icon 3.0 front coil overs
  • Icon 3.0 front secondary bypass shocks
  • Camburg UCA
  • Camburg LCA with secondary shock mount
  • Camburg secondary shock upper mount
  • SDHQ Frame doubling plates
  • SDHQ Metric alignment cams
  • SDHQ Knuckle reinforcement gussets on standard F-150 knuckles (welded myself)
  • SDHQ ABS/Vacuum guards
Engine:
  • K&A CAI with pre filter
  • Stainless works Turbo-S muffler, offset in centre out, stainless turn down with J-Tube resonator
Brakes:
  • Crown Performance SS Braided lines +2" over stock
Wheels:
  • Method NV 17" Black
  • Duratrac 315/70/17's
  • 2 spares (1 Duratrac, 1 BFG)
  • Gorilla splined black lug nuts
Electronics:
  • Icom ID-880H 50W Radio
    - Browning BR-158-S 150-170 MHz VHF NMO Antenna
    - Browning WSPBR1015 Enclosed Nmo 3/4 Hole Mount
  • Cobra 75WXST
    - Browning BR-140 CB Land Mobile Antenna
  • DeLorme InReach Explorer Two Way Satellite Communicator
    - Ram dash mount
  • ****** Passport Max2 HD Radar Detector
  • Samsung Galaxy Tab S2 9.7"
    - Arkon Heavy-Duty Tablet Mount (Custom Mount for Icom Radio face plate on the top)
    - Garmin GLO Portable GPS and GLONASS Receiver
    - iSaddle Super Mini ELM327 V1.5 OBD2 OBD-II Bluetooth CAN-BUS adapter
  • Hard wired power for radar/gps/phone in headliner dropping out behind the mirror
  • Viper 5906v with Smart GPS module
    - Alarmed light bars
    - Alarmed tailgate/cap
  • Pop & Lock PL8250 Power Tailgate Lock
  • Custom switch panel in headliner
    - 10 Rocker switches
    - 5 Push buttons
    - CNC Machined aluminium plate
Bumpers:
  • Custom front bumper using a recycled SVC baja top tube
  • Custom rear bumper
Racks and storage:
  • ARE Z-Series Topper with power lock
  • Custom light tower with 2 rear facing ambers
  • Smittybilt Defender Roof rack 40404 with AM-4 mounting kit
  • Rouge Racing tire carriers with bed side braces
Other:
  • Line-x'd bed
  • H&R Fire extinguisher mount under drivers seat
  • Custom hood wrap from Designs and signs - won in the november pay it forward thread to help Avery get her pup.
  • Black roof (plasti-pid).
  • Master Lock 8253DAT Tailgate Loc
  • Dee Zee DZ43200 Tailgate Assist
Winch:
  • Smittybilt X2O 12k winch with synthetic line
  • Rough country winch mount
  • Masterpull gusseted thimble
  • Factor55 Prolink
  • 50' Masterpull extension
  • Line repair and splice kit
Gear:
  • Traction pads
  • 2 Spares
  • 10 Gallons fuel
  • Recovery strap
  • Kinetic Rope
  • Shackles (4)
  • Snatch blocks (3)
  • Tree savers (3)
  • HiLift Extreme jack with offroad base
  • Jack Mate
  • Shovels (Folding and large)
  • Full tool kit
  • Smittybilt CO2 tank
  • Impact wrenches (Pneumatic & Electric)
  • Automatic tire deflators
  • 50' Winch extension
  • ARB Tire Deflator
  • PowerTank Heavy Duty Inflator
Runs:
  • GLRE Time Attack 2014
  • GLRE Rise of the Phoenix 2014
  • RallyCross IL - September 2014
  • WI Raptor Run - August 2014 - Lead/Chase
  • Snowball 3 - January 2015 - Bravo 1
  • WI Raptor Run - April 2015 - Lead/Chase
  • RallyCross WI - May 2015
  • SD/WY/MT Road Trip - June 2015 - Solo
  • Jackalope Run - July 2015 - Lead/Chase
  • Silver Lake Raptor Run - Sept 2015 - Chase
  • WI Raptor Run - Sept 2015 - Lead
Todo/Idea List:
  • Fab dual light cannon mounts for hood
  • Fab roof basket and endo-skeleton for the cap
  • Powder coat and install rear bumper
  • Sandblast rust from frame and repaint
  • Finish rebuilding all shocks
Deleted member 12951
Guest
Going to have that all done by Snoball?
Curious, what made you decide on Camburg to go with the Icon's? What kind of wheels you got?
t_j
t_j
Chicago, IL
There are not many options for dual front shock setup, and I prefered the looks and options on the camburg (jack point for example).
And yes I am hoping to get this all installed without getting frost bite before snowball.
t_j
t_j
Chicago, IL
Antenna mount:
Sitdown
Suburbia, IL
You've had such awesome stuff brewing in the shop and all you post is the antenna mount, show us more Tomas!
93,171
56,440
jumpcutter
