GEN 1 So I have these 37's and now having issues??
T
thedefboy
So when i got back from Baja i had to replace the upper control arm and the factory one isn't serviceable. I had Camburg Upper control arm installed mid perch , stock wheels with 37 x 12.5 x 17 Cooper Discovery Maxx tires.
now i have had issues with the hose for the air locker/shiftier system to engage the front wheel hubs and the top of the ball joint is rubbing the inside of the wheels (just a bit ) enough to rub some paint off it.
I dont want to have to rebuild the whole front end or go down to stock tires if i dont have to. I will post a few more pictures to show what i am dealing with.
T
thedefboy
I am not apposed to removing the inner wheel cover and re working the metal behind it , just not sure of what is needed , some pictures of what was done on others trucks would be helpful rather than just guessing . Thanks for the input in advance.
T
thedefboy
Thanks Pacific Wheel , the ones you suggested are the ones on the truck now, i believe..
Pacific Wheel
Reno, NV
That at least makes sense as to why you're rubbing the UCA. The only options to remedy that would be lower offset wheels but don't worry I know a guy ;) or changing the UCA's to the 1.25" uniball. You could always run a spacer but I'd advise against that.
