85eurocarrera
Is it the miles/age or a little of both that determine the condition of the fox Shocks? Im looking at 8-10yr old trucks with under 50K miles. Do i budget for rebuild right away?
Thank you.
Thank you.
Thank you.
Is this a straightforward swap?Instead of rebuilding my 65k mile 2018 shocks, I’m replacing them with brand new 2019-2020 live valve shocks. They were cheaper than “rebuilding” my current ones.
What is the benefit in the newer shocks if you’re deleting the live valve component?pretty much, although if you're throwing them on a 2017-2018 Raptor without the live-valve shocks, then you have to install RPG's delete kit - which sets the shock to it's softest setting. Then of course make sure they are filled at the right amount of pressure. RPG has a video explaining and installing the delete kit on youtube. Raises the truck up a bit both in the front and rear as well.
