Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Staun's internal beadlocks are supposed to be excellent products but they're not as popular as the external ones because no one can see them :mrgreen: seriously, I hear they're quite good but probably not best suited to the Raptor's typical use.
the theory makes sense, the application doesn't. they are supposed to work like an inner liner puching the beads of the tire onto the wheel, allowing the use of lower inflation. I don't believe that they could be used with the psi sensors either. Unless they have changed since I played with them you'll need to drill an additional hole in the wheel as well. I'd spendthe money on an air tank or a compressor or an extra spare tire & wheel
