p0657, p0740, p0750, p0755, p0760, p0765, p0770
Westside Offroad Group
Westside
fuuu ****** up my truck
here's everything rele:vant I can think of
-installed Volant on Friday
-tuned 91 performance tune from 5star with update for the volant
-went offroading today, at the very end of the offroading I get a CEL on dash
-check CEL, code was p0657, and transmission stuck in 3rd gear
-tried clearing code with the SCT tuner, it came right back
-drove home 50 miles and checked codes again, got p0740, p0750, p0755, p0760, p0765, p0770
-reset tune to stock, no help
-reset KAM, no bueno
now what do I do :(
Ni9mm
Florida
I did not go offroading today I got No problems. You had way more fun. Somebody give my man parts to someone else.
Cleave
Oxnard, Ca
P0657 Actuator Supply Voltage "A" Circuit/Open, I'm gonna say you lost power to your transmission control module in some way, which caused all the other codes you're experiencing, make sure you have your dealership focus on the p0657 code if you're going to have them work on your truck
---------- Post added at 05:01 PM ---------- Previous post was at 04:59 PM ----------
The rest of the codes are shift solenoid malfunction codes, they aren't the cause of your problem, just a symptom
Hockster
My 45ft Bluewater Party
Winchester, Va
P0657 - Actuator Supply Voltage A Circuit/Open
Description:
Possible Causes:
Diagnostic Aids: Refer to the Workshop Manual Section 307-01, Automatic Transmission, Diagnostic Trouble Code (DTC) Index to continue diagnosis.
Application Key On Engine Off Key On Engine Running Continuous Memory
All Refer to the Description, Possible Causes and Diagnostic Aids for the DTC.
P07xx - Transmission Code
Description:
Possible Causes:
Diagnostic Aids: Refer to the Workshop Manual Section 307-01, Automatic Transmission.
MTF
Celebration, Florida
Sometimes after you install a Tune it helps to disconnect the battery to force the PCM to start a new learning cycle.
But with all those error codes something else might be going on.
Hockster
Winchester, Va
P0740 Torque Converter Clutch (TCC) solenoid TCC solenoid circuit/open The PCM detected that the TCC solenoid control circuit failed open. MIL ON
TCC is disabled
DTC P0743 may set
GO to Pinpoint Test
P0750 Shift Solenoid A (SSA) SSA The PCM detected that the SSA circuit failed open or shorted to power. MIL ON
5th and 6th gear only
DTC P0753 may set
GO to Pinpoint
P0755 Shift Solenoid B (SSB) SSB The PCM detected that the SSB circuit failed open or shorted to power. MIL ON
Default to 3rd or 5th gear
Harsh 1-3 shift
DTC P0756 may set
GO to
P0760 Shift Solenoid C (SSC) SSC The PCM detected the SSC circuit has failed open. MIL ON
Disable 2nd and 6th gear
Erratic or harsh 1-3 shift
DTC P0763 may set
GO
P0765 Shift Solenoid D (SSD) SSD The PCM detected that SSD circuit has failed open. MIL ON
Disable 1st, 2nd and 3rd gears
Poor launch performance
DTC P0768 may set
P0770 Shift Solenoid E (SSE) SSE The PCM detected that the SSE circuit failed open, shorted to ground or shorted to power. MIL ON
No TCC
If 1st, 2nd and 3rd gears are achieved than circuit is open or shorted to power (no pressure)
If 5th gear launch than circuit is shorted to ground (pressure)
DTC P0773 may set
---------- Post added at 08:23 PM ---------- Previous post was at 08:22 PM ----------
Seems to all point to the Torque conveter
Cleave
Oxnard, Ca
The tunes and other modifications have nothing to do with jb's truck failures, he's most likely having a wiring failure
