Sungod661
- Joined
- Aug 20, 2016
- Posts
- 273
- Reaction score
- 92
Yup lights .... if you want to sell em
Let me know
Let me know
I took the light bars out last night. With the brackets it does look like it could be part of the problem for sure. I left my lower vision x light bar on. If that doesn’t work I’m going bigger radiator and oil cooler and opening up the skid plate for more air flow. I might just take the skid plate off next time to see how she does. I think with the light bars, ic and bumper it just isn’t getting air.
A thermostat isn't going to do shit, guys. Why do you think it will? His fluid temp was 258. Do you really think the OEM thermostat was closed???
I run an upgraded CBR radiator (and oil cooler) in my truck. Very happy with it. I'd put your lights back on and get the bigger radiator. It's only a grand or so and given everything you have put into the truck already, that doesn't amount to much.
https://www.rpgoffroad.com/product/cbr-oem-ford-raptor-replacement-radiator/
I would give CBR a call and find out if they have one for your truck. Heat is an engine/trans killer.
Btw, I also run the upgraded OEM trans cooler.
Thermostat probably won't help much, but it's pretty cheap to swap all things considered... A bigger radiator won't do shit if it isn't getting enough air... As mentioned, those square lights could be diverting most air from entering the areas above and below the intercooler which is why he is having a problem. He is literally the only person I've seen/heard of that is having cooling issue with the IC there - and really the only one I've seen with lights behind the grill with that IC as well.
