New shoes....finally!
SDHQJASON
Gilbert, Arizona
I like :)
Will be upgrading brakes to Brembo Gran Turismo, they need bigger rims for the calipers with the 15" rotors anyway.
Link to MTH:
MHT Wheels Inc. : Gallery
This must your truck Brace37, right?
Question, since there are 1.2" larger in dia. and only 0.3" in width then the stock tires,
do you notice any differance in transmission shifts and any noticable speedo readings?
Jason@SDHQ can answer for me as well, because when I'm ready I'll be giving you a call!
The speedo will be off by roughly 3 percent at 65. So the speedo will read about 67. These are based off quick calculations based on the change in diameter which goes from 108.016 inches to 111.156 inches.
Maxx2893
Rock and Roll Offroad
Burleson, TX
I think you mean circumference. Other wise you'd need more than perch adjustment :grenade:
MTF
Celebration, Florida
You have to change it to circumferance in order to work the formula.
I just put in the height because I had both tire sites open and put in the info.
