new gen 1 member
kiwi
san diego
i guys, im near san diego california, i have a blue flame gen 1 crew.
im experiencing a couple of issues with my rap.
1- when prees or depress the brake pedal it makes a funny noise , like a moaning cat , i have lubricated every part i can barely see , but i continued, any suggestions?
2- my 4x4 doesnt work, it worked before, it sound like the motor on tcase works, theres no leak on vacumm, i think it might be iwes?
no 4x4 issues on the dash.
3-front camera i had never be able to work….
any recomendation will be appreciated
Gen1TillDeath
cincinnati
2: so you can hear the transfer case trying to engage when you go into 4wd? IWE’s would be a good place to start. If you don’t here it trying to engage, might be the selector switch in the dash. Those go fairly often.
3: your using the right sequence to enable ?
Sequence = pull rear locker, off-road mode, then enable in 4x4 setting, put truck in drive. Maybe try and unplug and re seat the connector
K
kiwi
san diego
it actually 4x4 doesn’t make any weird sound , display says it is in 4wd but it doesn’t
K
kiwi
san diego
yes it sounds when the tcase motor engages, actually i just change the tcase motor just in case and nothing, keeps in 2wd.
when i turn the car off the front drive shaft (manually) when i turn it it moves the front tires with no issues..
im lost here
