Mid-Travel 3.5TT
Discussion in 'New Member Check-In' started by Pinero61, Sep 2, 2014.
  1. Pinero61
    Pinero61 Member
    23
    6
    Sep 2, 2014
    Houma, La
    Lol, thanks.
    I haven't been too active in this forum (other than the classifieds), but now that it is getting closer to the release of the second gen trucks I'll be much more active here.
    There's hate for the Eco no matter where you go. It's just an easy target, lol.
    I definitely did not want to build a clone. What I wanted wasn't offered, so I tailored the truck to meet my expectations. The second gen will definitely be more capable, and the 10-speed should be a nice upgrade. I can't wait to start playing with one.
  2. Pinero61
    Pinero61 Member
    23
    6
    Sep 2, 2014
    Houma, La
  3. Pinero61
    Pinero61 Member
    23
    6
    Sep 2, 2014
    Houma, La
    Gallo 24. The Gallo 34 was just too much.
  4. Jimbo
    Jimbo Mad Frog Mattis
    12,603
    8,863
    Sep 17, 2014
    IL
    [​IMG]
    13raptorcrew likes this.
  5. Pinero61
    Pinero61 Member
    23
    6
    Sep 2, 2014
    Houma, La
  6. customtruckshop
    customtruckshop Supporting Vendor Supporting Vendor Supporting Member
    920
    236
    Mar 12, 2012
    San Dimas, CA
    Welcome to the site!
  7. Truckzor
    Truckzor FRF Addict
    2,128
    1,129
    Feb 17, 2013
    I'm sure a 23 year old computer technician knows everything there is to know about motors and engines but to me it feels like 1989 all over again. Been hearing that same marketing hype since back then.
    New GM V-8 Proves Pushrods Still Rock | Vehicles & Technology content from WardsAuto
    RLTW likes this.
  8. Pinero61
    Pinero61 Member
    23
    6
    Sep 2, 2014
    Houma, La
    I have a heavy mechanical background, but work with electronics professionally. I now work as the Cheif Electrician aboard a semi-sub drilling vessel off the coast of Rio De Jenero, and have five years experience in the electro-mechanical professionally. Before that, I grew up in a family of gear heads around my fathers mech/body shop. I've been turning wrenches since I was old enough to hold them. Granted, I still lack the years of experience of some of the keyboard mechanics on here.
    That said, over head cam engines continue to make more power per liter, turn up more, and are more fuel efficient than their pushrod counterparts. Dodge's Hemi and the LS/LT 6.2L engines either do not or barely make as much power as ford's 5.0 overhead cam engine. Another great advantage to these engines are the ability to manipulate valve timing on both the intake and exhaust separately. This provides great tuning advantages.
    I still have love for the old pushrods, though. I've built a few growing up while helping out around the shop and/or my own projects. Hell, my first truck was an '86 Chevy step side that I spent over a year restoring and modifying. They're just not cutting it anymore...
  9. Truckzor
    Truckzor FRF Addict
    2,128
    1,129
    Feb 17, 2013
    That's a cute resume. You're an electrician who used to change oil in his dad's garage and now you know more about engine dynamics than General Motors, huh?
    Your generalizations about OHV vs. OHC are based on "per liter" measurements. But who cares about that besides the marketing department? Can you name some engines that can produce 460hp more efficiently than the new LT1?
    Fact: OHC engines are larger, heavier, and much more top heavy than their OHV counterparts.
    Fact: the most powerful cars in the world are powered by OHV engines.
    I have nothing against OHC engines. I have one. Did it escape you that the 6.2 is a SOHC? So I'm not even sure how pushrods came into the discussion in a Ford forum since Ford moved away from them a long time ago, but I couldn't resist the chance to point out your ignorance.
    Idleone likes this.
  10. Pinero61
    Pinero61 Member
    23
    6
    Sep 2, 2014
    Houma, La
    Haha, good one. No, I do not claim to know more than General Motors, or be a mechanical expert. Simply mechanically competent is the point that I'm trying to get across. I'm still young, and have much to learn.
    Now, let's put a little boost to that GM 6.2, and see how long those high compression hypereutetic pistons last. DOHC engines with variable valve timing (Ford 5.0) can over lap the intake and exhaust valves to reduce the effective compression ratio. This allows these engines to survive at higher boost levels without expensive engine builds. Granted, once you pass the threshold of needing a built engine, these will be more expensive to build. To a certain power levels, each engine has its advantage.
    As far as the 6.2 being a pushrod engine, you are correct it is not. Thank you for correcting me. Still though, SOHC and DOHC are different beasts when VVT is introduced.
    Truckzor likes this.
Share This Page
