Locks are not working properly (Gen 1)
Discussion in 'Ford Raptor Maintenance Forum' started by SS308, Nov 26, 2019.
Car Parts
  1. SS308
    SS308 FRF Supporting Member Supporting Member
    521
    232
    Dec 31, 2018
    Cheyenne, Wyoming
    Can not lock from the door panels, but the key fob works fine (locking and unlocking).
    Anyone run across this? If so, what's the fix?
    Thanks in advance.
  2. tltoronto
    tltoronto Full Access Member
    125
    53
    Nov 24, 2018
    toronto ontario canada
    Like, the interior panels right? Not, the keyless entry? If interior, you check your fuse? Keyless entry, does it light up?
  3. SS308
    521
    232
    Dec 31, 2018
    Cheyenne, Wyoming
    Thanks for the reply.
    - Interior panels. The fuse is good (first thing I checked).
    - Keyless entry (key fob) interior and exterior lights up.
  4. The Car Stereo Company
    The Car Stereo Company aka nosbusa Supporting Vendor
    41
    25,654
    8,812
    Jul 8, 2012
    here, on frf
    could be a bad switch panel.
  5. MTF
    MTF FRF Addict
    4,395
    1,277
    Nov 27, 2010
    NYC
    Does it work from the passenger side?
    If both sides don't work, it could be a bad BCM (Body Control Module).
    The plug connection from door to front A pillar is easily removeable by releasing the latch, may want to check inside there.
  6. SS308
    521
    232
    Dec 31, 2018
    Cheyenne, Wyoming
    Thanks everyone. I'll follow up with your suggestions (when all the snow clears).
  7. KCM
    KCM Full Access Member
    68
    22
    Apr 4, 2019
    California
    I have the same problem on my 2013. Have not been able to figure it out. Also my keyless entry works fine and then turns off after around 1 hour locking me out.
  8. SS308
    521
    232
    Dec 31, 2018
    Cheyenne, Wyoming
    LOL! Luckily that hasn't happened to me yet. I'm going to have it check out (It's under a warranty program) and will get back to you what I find out.
    What part of CA are you from?
  9. KCM
    68
    22
    Apr 4, 2019
    California
    Haha yes has locked me out after surfing a couple times. I’m from Orange County. Looking forward to hearing how you fix it!
  10. SS308
    521
    232
    Dec 31, 2018
    Cheyenne, Wyoming
    Was born in 29 Palms, Boot Camp at MCRD San Diego, Stationed El Toro (Marine Air Base, now closed) and Camp Pendleton. Have relatives in Livermore. Make a trip out there once a year.
    Sure has changed...
    SVTWillis and KCM like this.
Share This Page
