K&N Oil Filter for 2019 Raptor
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by Craig Post, Nov 9, 2019.
  1. Craig Post
    Craig Post Member
    Oct 20, 2019
    New Jersey
    Hi everyone. I just got my 2019 Raptor a few weeks ago and thinking of doing my first oil change at 1500. I've always used Mobile-1 and K&N filters in all my vehicles with great results so I'm going to continue doing the same with the Raptor .. problem is K&N doesn't call out an oil filter for the 2019 the HP-2011 says it's only good up to 2018. I'm thinking this is the same engine so it will work. Is there any 2019 Raptor owners out there that have used the HP-2011? Just want to confirm before I buy. I did call K&N and they told me they haven't completed testing on the 2019 so that's why they only go up to 2018. I'm thinking that's a bunch of bull and they just haven't updated their documentation yet.
  2. BroncoAZ
    BroncoAZ Full Access Member
    396
    204
    Sep 27, 2019
    Flagstaff, AZ
    There is nothing wrong or inadequate with the Motorcraft oil filter, and Ford’s OE oil is a synthetic blend that’s pretty good too. I really like Mobil 1 and K&N filters (I use both on my Bronco and Mobile 1 in my diesel with a factory filter) but why screw with it while the truck is under warranty? I always pay for dealer maintenance while the vehicle is under warranty so if I have a problem later there is no question on the vehicle being serviced correctly.
  3. Craig Post
    Craig Post Member
    Oct 20, 2019
    New Jersey
    I hear you .. I did check with my dealer and they said no problem with Mobile-1, K&N and doing the oil changes myself as long as I keep records and receipts which isn't a problem. I'm sure if you did 3k oil changes with any oil or filter you probably wouldn't have any issues and go well over 100k miles .. I just prefer the K&N filters and Mobile-1 which has done right by me on every vehicle I've owned.
  4. sixshooter_45
    sixshooter_45 Ruby Red Metallic Supercrew, 3.5 L Twin Turbos.
    793
    252
    Jun 17, 2012
    Arnold
    You may want to look at this closely and in the end it would be Ford calling the shots on engine repair.
    After studying this chart, I decided to stick with Motorcraft oil filters.
    Ford Oil Filter Cutaway Comparison
    Hawaiian Time likes this.
  5. Badgertits
    Badgertits FRF Addict
    1,118
    609
    Jan 24, 2019
    Ma
    I have a 2018 but 100k extended warranty & I use K&N oil filters because they’re easy to remove & good quality - I saw that chart & the K&N they’re comparing to the motorcraft & I don’t see anything to really be concerned about - also that’s not the same K&N that our raptors call for- the hp 2011 & that does have a silicone gasket. I believe I read that it filters out much finer particles than the motorcraft is rated for.
    Either way- wix, Fram, Bosch motorcraft doesn’t matter dealer can’t void warranty for using a different fluid or filter as long as it’s rated correctly & made to the vehicles specs.
  6. sixshooter_45
    793
    252
    Jun 17, 2012
    Arnold
    Wix is a great filter, most of Frams are terrible but I think they've one maybe two decent ones.
  7. pbtjrlmrt
    pbtjrlmrt Full Access Member
    398
    259
    Feb 21, 2019
    Oregon
    Ford also has an OE full synthetic. People don't seem to know that
  8. hekster1
    hekster1 Full Access Member
    119
    36
    Oct 27, 2018
    NJ
    I use Amsoil full synthetic and their filter. Used it also on my former Ram. Check Amsoil out great products...
  9. nikhsub1
    nikhsub1 FRF Addict
    1,796
    1,242
    Mar 5, 2017
    Well their air filters are terrible so I don't see why you'd want to use their oil filter?
  10. brianh87
    brianh87 Full Access Member
    114
    50
    Mar 3, 2019
    Pittsburgh, PA
    I haven't used one, but I like the idea of having a nut on the end of the K&N filter. The OEM one can be a pain to get off.
Share This Page
