I just want 1 inch lift in rear?
CatchMeOffroad
USA
I know majority of u guys hate blocks in the rear but I don’t want to dump 1400 for +3 deavers now.
Wondering if anyone has ran blocks in the rear just to get 1” raise. That’s all I would need or want.
Wondering any kits u have seen for the rear.
I took the truck to a local spring shop; they added a leaf and re-arched the springs to get me about 3" of height. Only cost $340 including new U-bolts. Rides exactly the same but has a lot more rear height now.
2 other local raptor owners did the exact same thing once they saw my results.
Brandin10
I'm interested in this modification as I carry around 600Lbs of tools at all times. How much did this help your payload? Hoping to increase payload a little so that loaded with my gear there is no squat
CatchMeOffroad
USA
I don't have a measurable number, but the guy at the shop said that it won't squat much with a couple hundred pounds more in the bed. I know it will increase payload, just not sure by how much.
I carry a big plastic tote filled with offroad gear (probably 50-70lb) and two 5-gal gas cans in the bed all the time, and with the new leaf and re-arch the rear still sits up a couple inches higher than the front. I would definitely recommend this mod for your situation.
Hope that helps...
ljn21
Tega Cay, SC
Hi OP, what did you settle on doing to get the 1" of lift in the rear?
