jcl48
Hi everyone:
I need some Help and Suggestions from anyone that knows about Suspensions on our trucks.
My Complete Suspension setup is the following:
● RPG Lower Control Arms
● RPG Upper Control Arms 1.5"
● RPG Steering Tie Rods
● RPG Frame Support and Fox Bump Stop Kit
● National Leaf Springs "Standard Duty"
● Fox 3.0s Front and Back
Current Issues:
1) I recently Installed all 4 Fox 3.0s I Have only driven the truck with them for about 2 to 3 weeks. At the time of Installation of all 4 Shocks I also installed the complete RPG front Suspension (LCAs, UCAs, and Tie Rods)
But the 4 Shocks NEW from Texas Motorworx, Great people to deal with 5☆ Customer Service.
I can hear some rattling sound from rear shocks (Still not sure if the sound comes from shocks or Leaf Springs) I assume rear shocks, since the only thing replaced on rear suspension were the shocks. We Torqued every bolt and nut according to SDHQ TORQUE Specs for our trucks. The rattling sound I can hear sounds something like "CLICK CLACK" and it only sounds when suspension is working (Compressing or Rebound) I climbed to the rear bumper and started bouncing up and down the rear end of the truck and succesfully replicated the sound I could hear when driving. Unfortunately when I crawled underneath the truck to check it nothing moved while wife replicated the sound succesfully. while I was down there found out what looks to be a very little leak from the Rear Right shock. Will check it again tomorrow morning since today was a rainy day and not sure if it was water or oil.
I also checked the front shocks and also found a little leak from the Left Front Shock, here is a Picture.
2) I think its time to either order new Leaf Springs or have them Rearched.
As of today I felt the ride very very Bumpy, even the Fox Bump Stops hitted the landing Pads when going over Speed Bumps at very very low speed(3 - 5 MPH), and could literary notice that the Bumpy part of the truck was in the rear. As soon as I got home noticed that the truck isTilted to the left. At first I thought maybe a flat tire even though I didn't get any alert from the TMPS, Checked tires and all were ok at 46-47 PSI. So I ran to my work shop grabbed a tape measurer and Measured all 4 corners from Center HUB to Bottom of Fender Flare; that confirmed about an inch or more of difference from Left to Right.
The approximate readings where the following:
Left Rear 25.5"
Right Rear 26.75"
Left Front 24.75"
Right Front 25.9"
Can anyone Suggest the best thing to do, and What might be causing all these issues???
Tomorrow morning I will take it to a friend shop that its specialty are Leaf Spring, so they can check them and unmount them to see if those can be fix and rearched.
Should I go with a new Set of Nationals HDs or the ones I have (SD) can be modified for them to be similar to the HD while also increasing my stance for about an Inch or so than Stock?
By the way which is the Rear Factory Stance on our trucks???
I have only had the Nationals and frame support with Bump Stops Installed for about a year and a Half now. Little Mild Off-Roading, have never jumped with it, the most high speed I have gone while off-roading through mountaineous terrain is about 45 - 55 MPH due to Huge Cliffs to the side.
Current Issues:
Left Rear 25.5"
Right Rear 26.75"
Left Front 24.75"
Right Front 25.9"
