BigJ
- Joined
- Aug 5, 2010
- Posts
- 5,448
- Reaction score
- 1,559
I'm on the top perch, and have RPG tie rods and upper A arms. Stock springs and stock Fox shocks. The truck has 67k miles on it, and the suspension has been set up like this for around half those miles. I don't baby the thing, but I'm not an idiot with it either.
Over the past 10k miles or so, at slow speeds or stopped, the front end will creak. I can make it creak on command when (1) its cold and pulling out of the driveway, (2) rolling in reverse the first couple of feet after everything has warmed up, and (3) rocking the truck side to side from the outside.
I have confirmed it is NOT the control arms or tie rods. The sound is coming from (I'm almost positive) where the spring meets the top of the tower. As a test I drenched it once with WD40 and the sound went completely away for a little while.
Thoughts? Do you have the same issue? What's your setup? Any suggestions that don't involve taking everything apart?
