Exhaust coating or paint
atayl5513
Kentucky
Exhaust tips color (black) is fading. Anybody have recommendations on products they have used to coat them matte black?
aandrews109
Florida Panhandle
I’ve used Krylon Semi-gloss Black for years on exhaust pipes, mufflers and other stuff I didn’t want to be shiny under the truck. It holds up really well.
isis
PA
I need to do mine. Probably doing either bbq paint or chassis black from Eastwood.
Ruger
Northern Nevada
Rust-Oleum High Heat Flat Black, part number 248903.
Holds up well, but after several years I need to do it again before winter.
isis
PA
Do you guys do any prep besides wash the dirt off?
Morgan
San Antonio
I've always been told that good prep work is the difference between a good and bad finish. Scotch-brite pads to scuff and alcohol to clean afterward is probably the route I'd take.
Ruger
Northern Nevada
I start with a chemical that will dissolve petrochemical road gunk - paint thinner or lacquer thinner. THEN the Scotch-brite or fine steel wool. Finish with denatured alcohol to remove chemical residue and dust from the abrasive.
If you use a high-temp paint that requires curing, follow the instructions or the finish will not last as long.
Morgan
San Antonio
^^^ Great call to use paint thinner first.
