Engine raising rpm when door opens
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by Ecoop, Nov 14, 2017.
  1. Ecoop
    Ecoop Full Access Member
    123
    62
    Feb 7, 2017
    Here is a new one for me: started truck, cold start rpm up, idles down, open door and it raises up to 1200ish, shut door idle lowers to 600ish. Did it 10+ times over maybe 10-15 minutes finally just drove away and now it doesn't do it....any ideas?
  2. Ruger
    Ruger FRF Addict
    6,157
    4,538
    May 16, 2011
    Northern Nevada
    Get an exorcist. Your Raptor is haunted!
  3. smurfslayer
    smurfslayer Be vewwy, vewwy quiet. We’re hunting sasquatch77
    3,416
    2,017
    I’m with @Ruger.
    You need an old priest and a young priest.
    Ruger and mcote1 like this.
  4. solarwinds
    solarwinds FRF Supporting Member Supporting Member
    437
    315
    Mar 28, 2017
    DFW
    is it hot out ? u got a/c set to auto ? door open a/c goes max makes truck rpm go up
    good one. you got me to go test this b.s you owe me a beer now :flipthebird:
  5. CSJr
    CSJr Full Access Member
    298
    194
    Nov 3, 2016
    GA
    Just curious. Was your truck parked for a long time or had an accessory draining the battery? The voltage could have read your battery was low and even that little draw for lights when your door open caused enough pull for the engine to supplement battery.
    Either that or gremlins...
    (I like solarwinds answer better, replace lights with a/c and it sort of sounds like what he said)
  6. kandewinn
    kandewinn Full Access Member
    46
    612
    348
    Mar 12, 2017
    No Bro, its the cold air from your ac hitting the intercooler when the door opens...runs better!!! LMAO
    Micha likes this.
  7. Big Johnson
    Big Johnson Full Access Member
    68
    53
    Dec 20, 2014
    Southern Alberta
    Have you done any forscan changes? Mine ramps up when I get out with it running since the secure idle was enabled
    DrewFish11 and dlbb like this.
  8. SeXualAVENGER
    SeXualAVENGER Full Access Member
    222
    140
    Dec 1, 2012
    Peoria, IL
    Same here. Seems like what the OP is experiencing.
  9. Ruger
    Ruger FRF Addict
    6,157
    4,538
    May 16, 2011
    Northern Nevada
    Secure idle?
  10. K1llD4shN1n3
    K1llD4shN1n3 Full Access Member
    307
    219
    Jul 27, 2016
    Colorado
    I noticed it too after enabling secure idle in forscan
Share This Page
