Electronic blow off valve connector
Guy
Hey Guys...
So I haven’t finished my Gearhead review because I decided to drop the intercooler down and adjust my clamps and fix a little rattle.
When I dropped it this time, I snagged the wire that goes to the blow off valve.
It pulled out from “somewhere” and I can’t figure out where it yanked from to fix it.
Brown with a white stripe and grey and it connects to the BOV and acuates it.
I’ll include a pic. What’s killing me is that it’s short and yet I can’t see where it pulled ouT.
Can anyone shed some light so I can button this back up and finish my review?
Thanks!
solarwinds
DFW
front lower grill section runs along top line where top of cac front ends up on driver side
G
Guy
Are you able to elaborate further?
The two little wires pulled out from “something” a harness?
Not sure what you mean.
Could use the help!
Thanks
solarwinds
DFW
Could use the help!
Thanks
check out step 12 of the whipple install guide. has a color pic of the run
G
Guy
I found it.
It pulled out of a connector that clips up front.
Now that I found it.
Not a big deal.
Thanks for giving me the heads up!
k-rub
Tucson, AZ
Out of curiosity, did you find the rattle? I've been chasing a small rattle for a bit. It's hard to narrow down but coming from the same area.
G
Guy
I dropped down the intercooler,
Checked every bolt for tightness... hit a little WD40 in every joint, retaining clip, I could find and added a zip tied to every stray cable or harness.
Of course as you see above... I snagged the wire harness and thanks to old Solar.. I found the connector it pulled from up on the front bumper.... I pulled it out, soldered that bad boy back in place... and then shrink wrapped everything. Won’t happen again.
Anyway. I just finished buttoning everything up and I took it for a 15 minute drive. So far.... no rattle.... except for the shrunken brain inside my skull... I now have from laying on the ground in 15 degrees all day.
Members online
93,202
56,485
bjorn-dpc
