Deaver shackle bolt size?
Simplejack
dallas tx
Might be purchasing a used set deaver +3 for my 2018 screw. Owner is reusing the shackle bolts so I need replacements. Only thing I can get is 18mm from Deaver. I called them up and didnt get an answer for part # or if I could buy some. anyone have any uninstalled with a pic of bolt package they come in for part # or size. 2 days worth of looking led me to this 18mmx150mm or 18mmx140mm.
https://www.stengelbros.net/334-1938-18mm-x-150-Spring-Bolt-with-nut-and-washers_p_7300.html
thanks
R
Rick@FreedomMotorsports
Guest
Use the OEM bolts and nuts. That is what you use when you install Deavers. They do not supply you the shackle bolts/nuts. They supply you the front ones since you have to cut it out by the gas tank. So you can just use your existing shackle hardware.
But here are the parts for the shackle:
Bolt: https://www.tascaparts.com/oem-parts/ford-shackle-bolt-w717604s439
Nut: https://www.tascaparts.com/oem-parts/ford-strut-nut-w520216s440
And the front frame:
Bolt: https://www.tascaparts.com/oem-parts/ford-front-bracket-bolt-w709627s439
Nut: https://www.tascaparts.com/oem-parts/ford-front-bracket-nut-w714297s440
Hope that helps!
Rick
Simplejack
Simplejack
dallas tx
thank you! yes that's what I needed, the replacement for the cut bolt. maybe that would of been better wording but I'm not that bright.
much appreciated
