Check engine light, misfire.
Boost_it638
New Jersey
Have a 17 and went I started it up noticed the check engine light. Ford pass alerted me that there was a misfire detected. Drove it earlier in the day and nothing was wrong until later that nite when I had to run out to the store. Anyone ever gotten that alert befor? Everything is pretty much stock, just have a pedal commander but it's been install for a couple of months now. Plan on bringing it in to have it checked.
I can’t think of a way that a P/C could induce a misfire.
Is it driving ok?
zombiekiller
OG BooBooRunner
New Orleans
I had similar issues.
Mine ended up being 2 stuck Direct injectors and a munged up fuel rail. ( got bad gas once)
Sozzy12
South Idaho
I've read the Ecoboost does tend to foul plugs. My brother had to replace his at like 40,000
Tlh235
I got this one last week. Read it via my ngauge. This is what mine is. Gotta take it to the dealership next week.
Boost_it638
Boost_it638
New Jersey
befor this happened I had just got the truck back from getting the oil pan replaced.
Update....While on my way to the dealership to get the light checked out was waiting at a light and notice smoke coming from under the hood. Pulled over and look under the hood, the oil dip stick is hanging half way out of the block. I dunno if they forget to put it back while doing the oil pan or something built up pressure and popped it out. Trucks at the dealership, waiting to hear back from them.
Boost_it638
Boost_it638
New Jersey
Sorry it took so long to get back to this. The dealer couldn't find any codes for a mis-fire. Said the new ford app is a lil buggy after the update so that might be why I got a mis-fire warning. How ever they did find a few fail codes for a failed battery. They replaced the battery and everything has been good.
zombiekiller
OG BooBooRunner
New Orleans
that is exactly was happens on the 18s when the driver's side crankcase hose gets unhooked, or the sensor on the hose is malfunctioning.
It will also pop up if the PCV valve gets stuck open or is gutted ( as part of some of the aftermarket catch can offerings that will work on a 17, but throw this code on an 18)
