How To Change Fox Bump Stop Pad for Towing
Discussion in 'Ford Raptor How-To's and FAQs' started by Yukon Joe, Oct 7, 2014.
  1. Yukon Joe
    Yukon Joe FRF Addict
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
    I bought a set of used Fox bump stop pads that are purposed for increased towing capacity. The larger pad extends the original Fox bump stop by about 4". It does this by replacing the original pad. And adds adjustability to the RPG bump stop kit.
    Original, off-road and daily driver fix bump stop on the RPG kit.
    To remove the original pad at the end of the Fox bump is fairly easy. You Need to jack up the body of the truck to give enough room to install the new pad. I put a jack under the tow hitch and raised the truck far enough to where the wheels were still on the ground. I put jack stands under the rear recovery hooks for safety.
    The tools required for the change out are minimal.
    3/16" allan head socket & ratchet
    (Or wrench)
    7/16" socket & 1/4" ratchet
    If this is the first time you are changing the bump pad, you may also need the following:
    Medium flat head screw driver for prying
    Rubber mallet
    Anti-seize
    1) remove the cap screw and nylon nut with the 3/16" allan socket (or wrench) and the 7/16" socket.
    2) remove the bump pad. It is a tight fit. This is where the screw driver and rubber mallet come in handy.
    To remove the bolt, I had to use an Allan wrench to help push it through. uploadfromtaptalk1412686520501.jpg
    Comparison of the two pads
    3) once the original pad was removed, I cleaned the receiving cup on the bump stop with some 3M pads. As you can see, there is dirt and some slight corrosion.
    4) I put some anti-sieze in the cup and some on the mounting bolt. Align the mounting holes with the new larger pad.
    5) install the bolt and nut. Tighten them down.
    6) Repeat on the other side.
    7) Remove the jack stands and lower the truck.
    8) you will be able to see that the pad will be in contact with the strike pad on the axle.
    Once the truck was loaded and the popup attached we hit the road. An immediate difference could be felt. With the rear of the truck riding on the bumps stops we could feel every little bump in the road. My truck already towes well with the National HD Springs. So I did not care for the ride at all. It wasn't horrible, but didn't care for it.
    If I had a much heavier load to carry, I would use theses. But for long road trips with the popup, I'll probably forgo them.
    Once we got to camp for the Havoc in the Hills II run, I changed the bump pad back to the original. It was quite simple and took me about 15 minutes. Including opening a beer and getting the tools out of the off-road tool box.
    I'll load more pics once this is approved and I can add another post.
    Yukon Joe
    Run Raptor Run | Great Lakes Raptor Excursions (GLRE)
  2. Hole Shot
    Hole Shot FRF Addict
    40
    1,624
    844
    Nov 4, 2013
    Raeford, Nc.
    Anyone know where to get a set of these??
  3. Nick@Apollo-Optics
    [email protected] Supporting Vendor Supporting Vendor
    5,454
    1,842
    Apr 3, 2011
    I'm sure @RPG would be able to help y'all out!
  4. Yukon Joe
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
  5. Hole Shot
    40
    1,624
    844
    Nov 4, 2013
    Raeford, Nc.
    There coming with my new bumps.
  6. Yukon Joe
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
    Nice! You'll have to post your thoughts on them once you get a chance to tow with them.
    Yukon Joe
    www.RUNRAPTORRUN.com
  7. trayack
    trayack Full Access Member
    39
    214
    33
    Sep 20, 2012
    Nantucket, MA
    Question, does this help with the excessive sagging? When I load my vette on a Uhaul car trailer the truck dropps right down onto the bumps and is crazy nose high. I'll be doing more towing once racing season starts so if this will help the truck ride level I'd be all about it!
    - Travis
  8. Yukon Joe
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
    Yes it does.
    Thank You for your donations to Avery. We hit our goal!
    Yukon Joe
    Snoball 3
    Delta Lead
    www.runraptorrun.com
  9. Justinb
    Justinb Member
    35
    16
    Dec 29, 2013
    Curious how you like it 2 years later?
    So thinking of getting a 9500lb travel trailer would this be an option could I tow it without killing my suspension?
    Do you have a link to buy them?
    Thanks Justin
  10. Yukon Joe
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
    Hello @Justinb
    I didn't like the ride with these installed, but most of my travels are more than a few hours.
    If around town, or a heavier load, these are ideal.
    For now, my National HD +3" springs do what I need.
    If you are interested, I'll sell you this set. $50 out the door.
    @Yukon Joe :baby: :baby:
    Drive your raptor here!!!!
    ( * Y * )
    Trick_Raptor likes this.
Share This Page
