Caster/camber kit from ford after perch adj?
troycrna
Pirate Air mentioned a caster camber kit he put on his truck. Does anyone know if ford makes a kit. I called my dealer and they could not locate it in the system. When the truck comes in Monday I would like to have them do perch adj and camber/caster kit all in one. Any help is appreciated.
Raptizzle
FYT
Southern CA
I've got the kit. Just ask a shop that specializes in alignments and they should be able to set you straight.
troycrna
troycrna
sdhq has a kit for our raptors. Someone mentioned on the z that if you dont need the kit you shouldnt use it because it is more likely to slip. I think Im gonna go with the sdhq kit....it just looks beefier
pirate air
will plunder your booty
The SDHQ kit is made by a company called Specialty Products. They are a very good company and its the same kit I have on my truck. I actually prefer it over the Ford kit. You should be able to get Specialty Products at just about any alignment shop, but SDHQ does have pretty good pricing on it.
And my arms moved way more before the kit was installed. After the kit, my arms hold in place much better. I'm pretty good at knocking my front end out of alignment lol.
pirate air
Its used to adjust the front lower control arms during an alignment.
Members online
93,202
56,485
bjorn-dpc
