battery issue maybe ?
greatone99
ma
left my lights on overnight ,battery was drained fully ,I charged up to 50 percent ,took 4 hours ,then the truck started ,I took for a 2 hour ride ,battery voltage went to 14 volts once but mostly stayed at 13 ,and a few times 12.5 ,do u think I hurt the battery ,it use to run at 14.5 no matter what .
CoronaRaptor
CANADA
It may take a few charging cycles to recover, but oem batteries don't like being fully drained. If yours is more than a couple years old and out of warranty, I would invest in a new one. If you have a bad habit of leaving things on, I would invest in an AGM battery.
Tibi Steri
California
Does your Raptor have BMS? Did you use a voltmeter or you read the Volts in the dash? Is that a Gen2 Raptor or Gen 1?
dixonk
HMFIC
Oklahoma
Mine fully drained once and it never really recovered. The FordPass app kept sending me alerts that it was shutting down services to preserve the battery. I ended up swapping out for a Optima Yellow Top as I run a fridge in the bed.
G
greatone99
ma
gen 2 ,it has bms , I check with a voltmeter ,and it matches the dash reading .
G
greatone99
ma
I may have charged it to quick ,I charged it with a 16 amp charger ,I believe better to charge low and slow
Donovan
DC
Good thread to follow...
I think my battery is the original 78k miles, 2017. Might need to start considering this for the next winter
