GEN 2 Baby's First Oil Change
What should I do?
  • Part it out
    Votes: 4 25.0%
  • Fit 37s
    Votes: 6 37.5%
  • Sounds like cam phasers
    Votes: 3 18.8%
  • Put a Rough Country lift on it
    Votes: 3 18.8%
  • 22s or ****
    Votes: 8 50.0%
  • Total voters
    16
Aviator150
OK... My 2020 is coming up on 1000 miles. Oil life indicator still says 95%... So, be old school and change at 1000, or wait until the intelligent monitor tells me to???
I want to get-r-dirty now.
GordoJay
Colorado
I'm going to split the difference and make my first change at 5k. It's 2020 and they don't make them like it's 1964 anymore, thank god.
isis
PA
No reason to change before it tells you to. Ever. Preference is up to you.
RaptorVette
Corpus Christi, TX
This works really well to get the oil filter off.
Check this out at Amazon.com TEKTON 5866 12-Inch Oil Filter Pliers https://www.amazon.com/dp/B000NPR33O/?tag=fordraptorforum-20
i installed the Fumoto valve and did not like it. The hose didn't stay on that well and it drained really slow. I started taking the whole skid plate off and I'm tired of doing that. I just bought a different funnel and one of these to try next oil change when I just remove the smaller access panel.
Gsteve
the only for sure thing i can add is check your oil often until 10,000
RaptorVette
Corpus Christi, TX
Oh and for those that wait for the oil life monitor to go to zero, when I changed my oil yesterday, my stock 2019 had burned about a quart of Mobile 1 in 5,000 miles. The oil life monitor was at 52%.
Gsteve
They all seem to burn a quart by 5000 and settle in after that. I’d never let my oil get to even 25%
JohnyPython
Canada
The filter wrench is handy to have.
Just in case you didn’t know, there is a trough on the cross member under the oil filter. The oil will come out of 2 openings in the skid plate. I wipe the trough after.
Denvertaco07
Denver, CO
