GEN 2 Baby's First Oil Change
What should I do?
  • Part it out
    Votes: 4 25.0%
  • Fit 37s
    Votes: 6 37.5%
  • Sounds like cam phasers
    Votes: 3 18.8%
  • Put a Rough Country lift on it
    Votes: 3 18.8%
  • 22s or ****
    Votes: 8 50.0%
  • Total voters
    16
Braaaaptor
Starbucks Enthusiast
The drive-thru
Currently have 4700 miles on the clock and will be scheduling my first oil change. Had a few questions as this is my first time dealing with Ford dealership maintenance. Looking for some general advice on what additional preventative maintenance I can ask for.
-Would the tech preforming the work install a Fumoto valve for me (or at least let me get under the truck while the plug is removed)? Want to make future oil changes easier on everyone and leave the undercarriage as mess free as possible.
-Would a tech lube the rails of the moonroof with the recommended Krytox lube if I asked? Or is this only allowed if undergoing the TSB for a rattling roof? Want to ensure the correct PM is done however the lube itself is expensive.
Before anyone asks, yes I bought an extended service plan for the truck. Current lifestyle necessitated it otherwise I'd happily do the work myself.
Todd Sherman
NJ
I would highly recommend to have Amsoil or other quality full Synthetic oil used for your oil change. The Motorcraft factor Synthetic Blend is not a good oil.
37’s and F***ing send it.
You can ask them, I’d give it about a 75% chance of being done.
My local stealership did this free of charge with my all encompassing, somewhat pricey routine service. So yes, ask for it. This is cheap insurance against a time consuming and expensive repair. You may want to ask them to order or sell you some of the krytox grease. Internet lore says it’s very effective and friendly to the rubberized gaskets for the glass.
No judgment. Lots of folks farm out maintenance work, use the time you save to do other stuff on the truck - cleaning, wax, visual inspect, mods, whatever.
Big Blue
Administrator
Staff member
Admin
USA
I understand you have an extended service plan, but I would only use that for warranty related issues. IMO, your best bet is to avoid the dealership service department as much as possible. Do maintenance work yourself, that way you know it gets done right and with care. Definitely install the fumoto valve, Raptor oil changes are messy but not after the valve install.
Deleted member 17706
Guest
By the time you drive to your dealership, wait for an oil change (and whatever else), then drive back home, I can guarantee that you could have already changed the oil, added the Fumoto valve, and lubed the rails of your moonroof.
I understand you have an extended service plan, but I would only use that for warranty related issues. IMO, your best bet is to avoid the dealership service department as much as possible. Do maintenance work yourself, that way you know it gets done right and with care. Definitely install the fumoto value, Raptor oil changes are messy but not after the value install.
^^^^^ This!
JohnyPython
Canada
^^^^^ This!
I would burn a whole day going for an oil change. Plus, they’d try to feed me more BS for additional service.
I would not trust anybody to install the Fumoto except myself. I double and triple check everything.
JohnyPython
Canada
I should also add; Document any maintenance work you do so you have a record. I just write the details in my owners manual. I like to keep the oil filter box tops also. View attachment 145094
Great idea!
If you’re lazy like me, I snap a pic of the odometer @ the oil change interval. Shows the date and oil life %. Same with coolant level etc. I have a photo album on my phone where I drop all the maintenance pics.
Braaaaptor
Braaaaptor
The drive-thru
Appreciate all the great advice!
I agree with you all that if you want the work done well, the truck to be treated right, and the right parts to be used then you have to do it yourself.
This truck is quickly becoming my favorite hobby so I think I'll take the plunge and get everything I need to work on it myself. Logging the maintenance myself is a great idea too. Definitely stealing that one.
Buying a Fumoto valve now and will head to the store today to buy AMSOIL/filter/drip pan/kitty litter/funnel.
One follow up question, is there a way to reset the oil life monitor on the Ford Pass App or will it reset itself?
Thanks again!
