AWE 2FG install advice
MtopRaptor
Installed the 2FG last week, since then the drivers side tail pipe keeps pulling out of the over Axle clamp . This has happened twice. Apparently there is some additional tension on this side. Any advice? Thoughts on drilling and installing an 1/8" stainless rivet? Thanks
It sounds like it’s not fully seated. Disassemble and hit the male insert with some white lithium grease. Drive it in with a rubber mallet. Unless you turn bright green when you get angry, you won’t hurt the exhaust. Once you think you have it fully seated, continue to fully seat using the mallet. When you get tired, switch hands. (with the mallet, get your mind out of the gutter).
Grab a pint.
Get back under the truck and continue because you might think you’re done, but you’re not. Now, you’ve been beating on it for 20 minutes with the mallet and it’s not budging. retried a 3 pounder from the garage. Use a 2x4 or similar to absorb some of the impact. Bonus points if you employ a no bounce 3#’er ;-).
Continue inserting the uncooperative exhaust until all movement stops. continue the pounding for 20 more minutes.
grab another pint.
clamp the exhaust now.
retest.
Braaaaptor
Starbucks Enthusiast
The drive-thru
^ He's only half joking. I would check for a leak or a loose clamp under there that is your culprit. My neighbor and I took the better part of an hour just seating and ensuring that everything was tight.
Luckily I don't get jealous watching another guy manhandle my girl like that but afterwards we were both satisfied and sweaty.
Sara/AWE
Horsham, PA
Any time you have an issue like this, posting here AND launching in a support ticket to our team would be awesome. We use the support interactions to track and tackle issues proactively, whether it's an installation Tips N Tricks video I can make, a manufacturing change or a simple instructions update.
Please let me know if you got everything sorted with 2 pints, 2 hands and one mallet!
AWE SUPPORT IS HERE!
MtopRaptor
MtopRaptor
Thanks, I did place a ticket. I have not received a reply
93,180
56,460
khunter
