Anyone Running Top Perch With Factory Suspension?
RaptorFlipper
The Woodlands, Tx
Gents,
Just picked up an 18 lead foot. Want to put 37's on it like my 13. Looking to run Nitto Ridge Grapplers on Method rims. My 13 is on BFG AT's on mid perch. Did some minor trimming and no rubbing unless heavy off roading. Curious what I can get away with here. Searched for a thread on this but could not find. Anyone have any experience? Or point me to the gen2 thread on this subject? Would rather not do suspension lift. Any info greatly appreciated.
Jake17
★ REBEL LIFE ★
:win:
DEGBTI
San Diego
gen 2 does not have an adjustable perch like your Gen 1 did. Look at Gieser springs or SVC or aftermarket Fox shocks so you can adjust the preload to get the front up
TXRaptor
Wow! Ok. Good to know! Thank you.
You can safely ignore Jake, as he always posts the picture of the same tired hatchet job which others do NOT have to do to run 37s... :crazy:
Most people have gone with the Geisers progressive springs or aftermarket shocks, rather than the 2.25" perch collars for ride comfort. You are also going to need Deaver +3s out back to safely run 37s, which give you one more inch of clearance. (The stock 2" block is removed with Deaver progressive leafs)
trophycummins
Simi Valley, CA
Deavers do not provide any additional clearance for bigger tires. The axle still hits the bump stop in the same spot. (assuming you have added the appropriate bump stops for deavers)
TXRaptor
The +3s keeps them from rubbing under normal every day driving. And yes, I went with RPG bumps stops on mine.
TXRaptor
perfect for mall cruzin' :crazy:
I guess I could do the same hatchet job on mine that you keep posting about. :crazy::ROFLJest:
---------- Post added at 12:53 PM ---------- Previous post was at 12:48 PM ----------
I guess if going to starbucks is all that matters :ROFLJest:
I personally do not drink coffee or go to many malls, but when you live in the Texas Hill Country for half the year, having a capable off-road truck is a given. I can live with minor rubbing at full flex, since it seldom happens where I need to drive.
Here is the driveway at my lake house:
