37x13.5x17?
DMays
Tennessee
There may be a thread for this but I haven’t been able to find it. Can anyone confirm does 37x13.5x17 work on a 37pp with 0 offset without rubbing? Light off-roading at times but nothing that will cause full compression. I hate the bfg ko2 and want to change but the tire market is super behind right now. I have found ridge grapplers and Toyo mt in 13.5 but can’t find 12.5. Thanks
Hambone
Atlanta
Check Walmart.com. That’s where I got my Yokohama X-AT’s from. 37 13.5 r18 on 9x 20 offset. Full clearance I see some 37 12.5 17’s on there now
Nex
RIP CoronaRaptor
Washington State
Have you looked at either the Wildpeak or Baja Boss in 12.5? I ran both and are great tires.
DMays
DMays
Tennessee
I checked out the Baja boss. Looks like a nice tire. I’m weird with tires and stick with what I know but the shortage may help me try something else
So-Cal-Al-52
I Love Fossil Fuel
San Diego
There is a member on here with a code orange 37 PP with 13.5 wides and is running a perch collar and he still had to trim quite a bit to make them fit. I don't know what his offset is.
Here is a quote from another thread.
"Hello! I picked up a raptor recently with 37x13.5 toyo mts on a +1 offset wheel. Truck has perch collars, but thats it. Took it offroading and it obviously rubbed like crazy, mainly in the rear though. Lost a fender bolt on one side."
"I am getting different wheels and tires, and I want to keep 37s but I do offroad the vehicle to full compression. What offset wheels do I need to be looking for? I am looking at the factory BFG KO2 37s as well from the gen 3. Or am I better of just taking it back to 35s if I am pushing the truck offroad?"
thatJeepguy
GA
If you’re only doing light off roading why do you want all the nonsense that comes with 13.5’s?
DMays
DMays
Tennessee
I don’t want 13.5s really. It seems to be all I am finding in stock for the tires I prefer.
Nex
RIP CoronaRaptor
Washington State
Try a different tire. I know that you are partial to your favorite but 13.5 on zero offset will more than likely rub taking it off the rack. I liked by Baja so much I just put a set on my daughter's taco. I'd still have them on the 17s if I could have gotten them in the time frame I needed. But the Wildpeaks are not bad either. Glad I was talked into them.
