Anyone running 2nd perch with 2" drop shackle in the rear?
ALLOUTWARN
Anyone running 2nd perch with a 2" drop shackle in the rear? If so how does it sit, level, front higher or does the rear still sit higher than the front?
BAJASVT
SE Michigan
I don't run that setup and don't know the size of the OEM rear axle block, but if someone can measure their rear lift block then these photos should be pretty helpful.
FRONT: Middle Perch
REAR: OEM rear lift block replaced w/ smaller 1.5" block.
FRONT: Middle Perch
REAR: OEM rear lift block removed
Here are the full threads where I found those photos. There are a couple pictures of both trucks in each.
http://www.fordraptorforum.com/f9/took-rear-block-out-pics-2400/
http://www.fordraptorforum.com/f65/mtr-ks-lowered-rear-15452/
---------- Post added at 10:48 PM ---------- Previous post was at 10:32 PM ----------
FRONT: Middle Perch
REAR: OEM lift block replaced with 1.5" block and 1" Synergy drop shackles.
Owner claims 42.5" in the front and 42" in the rear.
ALLOUTWARN
ALLOUTWARN
ya, i just sold my 2011 screw and had it on the top perch and removed the factory block in the rear, it had a drastic rake or "prerunner stance". Just bought another screw and wanna run it on the 2nd perch this time and wanted to still have that prerunner stance, so i was wondering if i would be ok with a 2" lowering shackle or if i would have to pull the entire factory block again. I know the fact block measures to 2 3/4"
FLYING BONES
After doing some reading the conclusion on this for me was to go with the shorter block, not shackle. The shackle lost more travel than the small block, because the small block changed the position of the bumpstop as well.
Sent from my HTC6600LVW using Tapatalk
Raptizzle
FYT
Southern CA
I've run the drop shackle before on mid perch and it sat just about level.
Don't remove the rear block unless you change out to aftermarket springs. You mess with shock ride zone by removing the block.
