Adding USB and 12v Cig outlet
dudmleh522
AZ
Hey guys I am planning to add a USB and 12v outlet on top of the center dash (behind my built right phone mount)
I am thinking of using a add a circuit and tap it into passenger side fuse box.
I want this to be on al the time hoping to use a constant power. Any suggestion on which fuse to tap into? and which fuse amp should I be using for the project?
By the way I am already using 36 for my ham radio.
Passenger compartment​
Amp RatingProtected components
110ADemand lamp relay. Power seats relay. Glove box. Vanity lamps. Overhead console. Dome. Courtesy. Map lamps.
27.5AMemory module logic. Memory seat switches. Lumbar motor.
320ADriver door lock motor.
45ATrailer brake control.
520ANot used.
610ANot used.
710ANot used.
810ANot used.
910ANot used.
105ANot used (spare).
115ACombined sensor module.
127.5 AClimate head module. Smart datalink converter.
137.5 ACluster. SCCM.
1410ABrake.
1510ASmart datalink converter.
1615ATailgate release.
175AHUD.
185AIgnition switch and passive-entry passive-start start stop switch. Key inhibit solenoid.
197.5 ATow haul (O/D) cancel for floor or column shifter.
207.5 ANot used.
215AHUD. In car temperature with humidity sensor.
225AEPB. Power seat.
2310APDRG switch. Inverter. Driver side window. Moonroof. Vista roof.
2420ACentral lock/unlock.
2530ADriver door control module.
2630APassenger door control module.
2730AVista roof. Moonroof.
2820ANot used.
2930ANot used.
3030ANot used.
3115AAdjustable pedal switch and motor.
3210AMulti-function display. Global position system. Sync 1. Sync 2. Radio frequency receiver.
3320ARadio.
3430ARun-start relay.
355ARestraints module.
3615A360 camera module. Heated steering wheel module. Rear-view mirror. Rear heated seats.
3720APower distribution box run-start fuses.
3830A Circuit breaker.Rear window switches and motors.
figure1a
San Diego
That list does not look correct. Nothing on your list corresponds to what I have in my manual. Also, 17 on your lists says HUD and I don't think our trucks have HUD.
For what you are looking for, #4 should be an always on 20A circuit that is currently not used by any other accessories. I used that for an always on dash cam.
HighwaySentinel
︻デ┳═ー - - - - - - -
California
The OP has a 2018 Gen2, so that may be where the discrepancy comes in. It appears to be the correct list for a 2018.
D
dudmleh522
AZ
opps my bad guys didn't realize I was on Gen 3 section. Thanks for the heads up.
