prowakeskater
Pretty sure rain sensing wipers have nothing to do with the windshield. There is a sensor that mounts behind the mirror that detects water on the windshield and turns on the wipers.
are you sure about that
Rickoo,
I believe that the rain sensing wipers have a sensor attached to the inside of the windshield that detects change in the ambient current on the (outer) surface of the windshield when it gets wet. Kind of like the galvanic conduction of an EEG...
Eddie
Rain Sensitive Wipers (if equipped)
When equipped, the rain sensitive wiper feature replaces the intermittent wiper feature. The rain sensitive feature is active when the multifunction switch is in any of the 5 auto/intermittent sensitivity settings. The setting closest to OFF is the least sensitive to moisture, the highest setting being the most sensitive to moisture.
The rain sensor optically senses water on the windshield. An infrared beam of specific intensity lights a section of the windshield. The intensity of the reflected beam is measured and compared to the intensity of the transmitted beam. If there is water on the surface of the windshield, the beam distorts, reducing the intensity of the beam. If the beam is not reflected completely, it is interpreted as rain on the windshield and the windshield wipers are started.
The rain sensor sends data through the LIN to the windshield wiper motor. When the rain sensitive wiper feature is enabled, based on the data received from the rain sensor and the auto/intermittent setting on the multifunction switch, the system automatically activates and adjusts the wiper speed and frequency when moisture is detected on the windshield.
A gel-type lens is used as the interface between the rain sensor and the windshield. If the lens is missing or damaged, the rain sensing wipers can be inoperative. The rain sensor gel-type lens is part of the rain sensor and cannot be replaced separately on a rain sensor of this type.
The rain sensitive wiper feature can be enabled/disabled through the message center.
When the rain sensitive wipers are disabled from the message center, or the windshield wiper motor detects a fault with the rain sensor input, the windshield wiper motor changes to a default intermittent mode. The timing of the wipers correspond to a standard intermittent setting based on the auto/intermittent sensitivity setting on the multifunction switch.
